monitor-session is not working in IOS-Xr ?
usmansa2
Hi all,
I am trying to capture the packets from Cisco NCS-IOS XR but everytime i try to open the file it shows this error "the capture file has no Interface Description Blocks" My configurations are mentioned below. does someone has any idea that why NCS540 is behaving like that way.
monitor-session jb ethernet
destination file size 6000 buffer-type linear format pcapng
interface GigabitEthernet0/0/0/10
description **Connected with ASR920_Gig0/0/0/1**
cdp
ipv4 address 192.168.158.1 255.255.255.0
monitor-session jb ethernet direction rx-only port-level
monitor-session jb packet-collection start
monitor-session jb packet-collection stop write directory /misc/disk1 filename jbcd
RP/0/RP0/CPU0:NCS_LAB-1#run
[xr-vm_node0_RP0_CPU0:/misc/disk1/node0_0_CPU0]$tcpdump -r jbcd.pcapng
tcpdump: the capture file has no Interface Description Blocks
does someone has an idea why this error is being observed, even when i do the simple packet capturing without file format the pcap file is empty. interface is up and regular communicaton (ping) is happening on the interface
PS : this is not spam, previous post was blocked by modirator
balaji.bandi
what is the IOS XR code, I have used below guide and works for me :
https://www.cisco.com/c/en/us/td/docs/iosxr/ncs5500/interfaces/75x/configuration/guide/b-interfaces-hardware-component-cg-ncs5500-75x/m-configuring-traffic-mirroring.html
Only difference i extract from device and used Wireshark to view the file with .pacp (never tried .pcappng )
BB
usmansa2
even pcap is not working
usmansa2
not sure if its a bug
simon italy
Hi everybody,
I have problem with monitor session , its not available in switch in eve_ng, the image :  i86bi-linux-l2-ipbas , iam trying to figure out how I can abilitate it on the SW , anybody can help me ?
thank you
