11-09-2020 12:37 AM
Hi All,,
I am using Manage Engine OpManager to monitor the ASA's status, i managed to add the device successfully using SNMPv3
however it needs the correct MIB and OIDs to monitor the status of the pow supply and other hardware components
could you please advise on which MIB to use
thanks in advance
11-09-2020 12:44 AM
- Below you will find some info-resources on the matter, as I pointed out in one of the threads - low end models may not implement all MIB - features. Hardware status monitoring is probably limited too :
https://community.cisco.com/t5/security-documents/asa-5510-power-supply-status-via-snmp/ta-p/3160793
M.
11-09-2020 12:48 AM
thank you I have 5525
11-09-2020 02:32 AM
if you do not have corrct MIB or OID download from below URL :
https://snmp.cloudapps.cisco.com/Support/SNMP/do/BrowseMIB.do?local=en&step=2
you can look below :
1.3.6.1.2.1.47.1.1.1.1.2.11 = "Chassis Cooling Fan 1" [ASN_OCTET_STR]
1.3.6.1.2.1.47.1.1.1.1.2.12 = "Chassis Cooling Fan 1 Sensor" [ASN_OCTET_STR]
1.3.6.1.2.1.47.1.1.1.1.2.13 = "Chassis Cooling Fan 2" [ASN_OCTET_STR]
1.3.6.1.2.1.47.1.1.1.1.2.14 = "Chassis Cooling Fan 2 Sensor" [ASN_OCTET_STR]
1.3.6.1.2.1.47.1.1.1.1.2.15 = "Chassis Cooling Fan 3" [ASN_OCTET_STR]
1.3.6.1.2.1.47.1.1.1.1.2.16 = "Chassis Cooling Fan 3 Sensor" [ASN_OCTET_STR]
1.3.6.1.2.1.47.1.1.1.1.2.17 = "Power Supply 0" [ASN_OCTET_STR]
1.3.6.1.2.1.47.1.1.1.1.2.18 = "Power supply 0 Presence Sensor" [ASN_OCTET_STR]
1.3.6.1.2.1.47.1.1.1.1.2.19 = "Power Supply 0 Input Sensor" [ASN_OCTET_STR]
