Monitoring High Usage
chrisalvarado
I'm looking to monitor some high use switchports on a 3750G.  I'm looking for something that will send an alert should a port become around 90% utilized.  Any suggestions?
Joel Monge
One option would be CiscoWorks LMS.  For example, you can set DFM to generate a HighUtilization event and send an e-mail alert.  You can change the Utilization threshold under DFM > Configuration > Polling and Thresholds > Managing Thresholds.
There is also the Switch Port Report under Campus Manager Reports.  This will not generate an alert but you might still find it useful in some other way.
Don Jacob
Many SNMP based reporting tools like PRTG, MRTG etc should e able to do what you are looking for. And these tools have free versions too.
Don Thomas
Regards, Don Thomas Jacob http://www.solarwinds.com/netflow-traffic-analyzer.aspx Head Geek @ SolarWinds NOTE: Please rate and close questions if you found any of the answers helpful.
