Monitoring interface traffic in Prime infrastructure 3.9
gianda
We have Cisco Prime Infrastructure 3.9, i tried to add a tab under Monitor / Monitoring Tools / Performance Graphs to monitor utilization in RX and TX of a sub-interface but it give me the error No Metrics available for this Interface.
What can i do?
7 Replies 7
balaji.bandi
Are you configuring netflow or just interface statistics ? what device model and IOS code running ?
https://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-9/user/guide/bk_CiscoPrimeInfrastructure_3_9_0_UserGuide/set_up_network_monitoring.html
BB
I have already configured Netflow, it's a rouer Cisco ISR4431/K9 and have the IOS Version 16.06.06.
how does the config look like , did you configured the IP of prime ?
BB
Yes i have correctly configured netflow to the correct IP of Prime, if i go under Dashboard / Performance and under the tab Interface i can see the traffic that pass through the sub-interface.
marce1000
 - Check if this bug report could 'accidently' be applicable to your case too :
           https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvo95226
 M.
Nope, sorry, apparently that bug got fixed in the 3.6 version of Prime, we have the 3.9 installed, however i tried to remove the description on the sub-interface anyway but it remind me the same error message, tried also to clear the cache of the browser as Cisco suggested but it didn't help.
Hi Gianda,
Did you find a solution for this issue please?
