Moving Ciscoworks
tobin_jim
I have been left a Ciscoworks LMS server to manage and the drive it is installed on is running out of space.
There is a second empty drive in the server available to use.
Is there anyway to move the current installation to this other drive? Version is Ciscoworks LMS version 4.
Nael Mohammad
Level 5
Level 5
Nael Mohammad
Level 5
Level 5
You must uninstall LMS and do a custom installation on the second drive. Before removing LMS, use the backup and restore steps:
Backup:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.0/install/guide/bkppl.html
Restore:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.0/install/guide/rsbkppl.html
