MRTG & as5350 active call monitoring
dialink-ir
We're currently monitoring active calls with the following OID:
1.3.6.1.4.1.9.10.19.1.1.4
This works well; however, it only reports the TOTAL calls on all PRIs/T1s. Does anyone know of an OID which can measure active calls on each T1 individually?
Thanks in advance for any help!
Vince
drolemc
Level 6
Level 6
A list of all cisco MIBS is available at http://www.cisco.com/public/sw-center/netmgmt/cmtk/mibs.shtml. Select AS5300 under 'Cisco Access Products' and click go for a list of all as5300 MIBS.
theotang
Try the following...
cpmDS1ActiveDS0s
1.3.6.1.4.1.9.10.19.1.1.9.1.3
This OID did the trick!
Thanks for the reply.
Vince
