N540X-16Z4G8Q2C-A rebooted frequently
Eng.AD27
Hi dears
router N540X-16Z4G8Q2C-A restarted frequently  without any error  in  log
How can i  know  the  reason for  this  issue ?
FYI
#sh reboot history
Tue Jun 22 11:16:55.896 UTC
No DATE TIME (UTC) Cause Code Cause String
1 Jun 22 2021 05:03:13 0x0800001f REBOOT_CAUSE_PCIESVR_RESTART
5 Replies 5
balaji.bandi
as per the messge it rebooted due to PCI issue may be due to bug,
if this frequently happending raise a TAC case for RMA
BB
marce1000
 - Looks indicative for a hardware problem, you may however look into the current software version being used and or upgrade to an advisory release , if applicable. Check if the problem then becomes persistent or not.
 M.
Eng.AD27
I replaced it with another device same model and the same issue .. how can i know  the reason for reset ?
                    >... how can i know the reason for reset
 You already reported that in your initial post :
     #sh reboot history
   >..... 0x0800001f REBOOT_CAUSE_PCIESVR_RESTART
 Look into the current software version being used and or upgrade to an advisory release , if applicable. Check if the problem then becomes persistent or not.
M.
martincook1
According to TAC this is due to the following bug, https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvy05542
