N7K Write Error
Hi !
Recently I fixed configuration and try to save running-config on N7K.
But Error showed up like this;
N7K# copy running-config startup-config
[########################################] 100%
Configuration update aborted: request was aborted
I searched it and found this is N7K Error. but can't find to how to fix this bug.
How can I write running-config on this device?
Mark Elsen
        - FYI : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCtw54476
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Mark Elsen
 M.
       Beauty and terror
      Just keep going
       No feeling is final
the bug below might apply as well:
Copy Run Start Fails Due To /nxos/dme_logs 100% Utilization
CSCvc77151
Customer Visible
Notifications
Save Bug
Open Support Case
Description
Symptom:
Unable to save running configuration on a Nexus 9000.
N9K-1# copy run start
Conditions:
/nxos/dme_logs/ directory is 100% utilized due to svc_ifc_confelem.*.log or svc_ifc_eventmgr.*.log files
Workaround:
++++ Enable bash feature on the switch if it is not already on ++++
conf t
feature bash
++++ Enter bash shell, become super user, change to /nxos/dme_logs/ directory, validate you are in the /nxos/dme_logs/ directory, and list the contents of this directory to identify the files taking up the most space ++++
run bash
sudo su -
cd /nxos/dme_logs/
pwd
ls -l
++++ Delete the files taking up the most space ++++
rm
Further Problem Description:
In the current DME implementation the DME logs are stored in the two following locations within the file system:
[+] /logflash/debug_logs/
[+] /nxos/dme_logs
This is related to CSCux08144 which provides a fix for dme_logs in the /logflash/debug_logs/ directory only. This defect will address this issue in the /nxos/dme_logs/ directory.
