NAM 1 Configuration
mrcomm2000
Level 2
Level 2
Dears
How can i monitor the WAN traffic (POS) with the NAM. I have done all the required configuration in the manual,
Cat6500# configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
Cat6509(config)# access-list 100 permit ip any any
Cat6509(config)# vlan access-map wan 100
Cat6509(config-access-map)# match ip address 100
Cat6509(config-access-map)# action forward capture
Cat6509(config-access-map)# exit
Cat6509(config)# vlan filter wan interface ATM6/0/0.1
Cat6509(config)# analysis module 3 data-port 1 capture allowed-vlan 1-4094
What is the next step from the traffic analyzer?
BR
rmushtaq
Level 11
Level 11
You need to SPAN the source, turn on the collections and then should be able to monitor it in the NAM GUI
