NAM in Catalyst 6513
CSCO10456946
Hi, I hava a NAM module in a Catalyst 6513.
Fo r few days I expected this troubleshut:
The NAM module shutdown :
Jan 17 07:45:54.743: %SNMP-5-MODULETRAP: Module 3 [Down] Trap
Jan 17 07:45:54.747: SP: The PC in slot 3 is shutting down. Please wait ...
Jan 17 07:46:23.943: SP: PC shutdown completed for module 3
Jan 19 17:20:05.640: %C6KPWR-SP-4-DISABLED: power to module in slot 3 set off (Reset)
Jan 19 17:22:48.362: %DIAG-SP-6-RUN_MINIMUM: Module 3: Running Minimum Online Diagnostics...
Jan 19 17:22:50.862: %SNMP-5-MODULETRAP: Module 3 [Up] Trap
Jan 19 17:22:50.478: %DIAG-SP-6-DIAG_OK: Module 3: Passed Online Diagnostics
Jan 19 17:22:50.862: %OIR-SP-6-INSCARD: Card inserted in slot 3, interfaces are now online
Jan 19 22:43:15.142: %SNMP-5-MODULETRAP: Module 3 [Down] Trap
Jan 19 22:43:15.146: SP: The PC in slot 3 is shutting down. Please wait ...
Jan 19 22:43:45.150: SP: PC shutdown completed for module 3
I found that this module lost conectivity with SUP module:
Jan 19 20:23:03 BV-NAM-2 rmond[690]: Falcon: not getting any spackets!
Jan 19 21:23:03 BV-NAM-2 rmond[690]: Falcon: not getting any spackets!
Jan 19 22:23:03 BV-NAM-2 rmond[690]: Falcon: not getting any spackets!
Jan 19 22:43:17 BV-NAM-2 rmond[696]: rmond: lost connection to SUP
Jan 19 22:43:17 BV-NAM-2 scpd: scpd: shutdown of NAM!
Jan 19 22:43:18 BV-NAM-2 rmond[690]: rmond: received QUIT signal! Exiting!
Jan 24 08:27:33 BV-NAM-2 scpd: scpd: Module Online
Jan 24 08:27:40 BV-NAM-2 nam2: Running ntpdate ...
Jan 24 08:27:42 BV-NAM-2 rmond[688]: rmond 3.1(1a) starting
Jan 24 08:27:46 BV-NAM-2 rmond[694]: rmond connected to SUP (127.0.0.12)
Can anyone help me with an advice.
Thanks in advance
sachinraja
Level 9
Level 9
hi
you can see if the following URL is helpful to troubleshoot the NAM:
http://www.cisco.com/en/US/products/hw/switches/ps708/products_command_reference_chapter09186a00801fadb7.html#wp1036907
do let us know if this helps..
Raj
rmushtaq
Level 8
Level 8
Reset the NAM module. If it comes back up. Upgrade it to the latest code+patch level first. Then see if you still run into the same issue again. This will help narrow down whether the issue is related to software or a problem with the hardware itself
