NBAR protocol-pack loaded BUT NOT ACTIVE
SAMEHELSAMMAK
DEAR ALL
MY ROUTER IS CISCO ISR4331
OS : isr4300-universalk9.17.05.01a.SPA.bin
I AM USING THE NBAR protocol-pack : pp-adv-isr4000-173.1a-40-57.0.0.pack
I LOADED IT ON ROUTER
ip nbar protocol-pack bootflash:pp-adv-isr4000-173.1a-40-57.0.0.pack force
IT SHOWS LOADED BUT NOT ACTIVE
ISR4331#show ip nbar protocol-pack loaded
Loaded Protocol Pack(s):
Name: Advanced Protocol Pack
Version: 54.0
Publisher: Cisco Systems Inc.
NBAR Engine Version: 42
State: Active
Version: 57.0
NBAR Engine Version: 40
Creation time: Wed Jun 16 08:29:15 UTC 2021
File: bootflash:pp-adv-isr4000-173.1a-40-57.0.0.pack
State: Inactive
ISR4331#show ip nbar protocol-pack active
Active Protocol Pack:
Version: 54.0
State: Active
HOW TO MAKE IT ACTIVE ?
balaji.bandi
If you like to use new one you need to use command force  - below for reference.
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/qos_nbar/configuration/xe-3s/NBAR_Protocol_Pack.html#GUID-1084080C-52AB-4320-A191-DF9E733418CD
BB
