NBAR2 from ISR-G2 to Prime Infrastructure 3.1 via Netflow.
Goga
Hello!
We currently planning to implement Netflow Export to Cisco Prime 3.1 from ISR G2 3945 with NBAR2 application recognition for Application Performance monitoring. Now we only configured Netflow monitor and export to PI (only shows http, icmp etc. and many unknown traffic)
Limitation is that we cannot deploy AVC template config from Prime Infrastructure to ISR.
What configuration is enough for this purpose? Do i need to add "match application name" string to flow record config or i also need to enable "ip nbar protocol-discovery" on every interface that we configured for Netflow?
Thanks in advance!
Hi Goga,
I have the same issue, how did you proceed with this?
Thanks!
