I am running a NCS Prime Wireless 1.1.24 ... and i have the following questions/problems..
1. Can we change the Font Size on the printout of the guest data generatet via NCS??
2. If i login simultan with two same usernames (lobby ambassador) i see a different Homepage ..
With firefox it works as designed, if i login via IE9 with the same username simultan i get the starthomepage of the NCS without the config buttons...
Anybody the same problems ??
Thanks Chris
