NCS Prime Wireless
I am running a NCS Prime Wireless 1.1.24 ... and i have the following questions/problems..
1. Can we change the Font Size on the printout of the guest data generatet via NCS??
2. If i login simultan with two  same usernames (lobby ambassador)  i see a different Homepage ..
    With firefox it works as designed, if i login via IE9 with the same username simultan i get the starthomepage of the NCS without the config buttons...
Anybody the same problems ??
Thanks Chris
ramkris2
Hi Chris,
1. No.
2. There is a symptom of the following bug:
CSCtw52442  NCS: Lobby Ambassador user can access the home page.
Installing Chrome frame plugin for IE browser in NCS is a requirement as documented in the release notes. This caveat is to address the issue where lobby ambassador users are getting access to the NCS home page to which they have no privileges for. For your IE users, install chrome frame plugin which should take care of it.
Ram.
