Need help turning off Standby Console Mode on a Catalyst Switch
ruffry999
Hey Cisco community,
Hope I can get an assist with the below issue.
Issue: Need to E-Waste a Cisco Catalyst 4507 R-E Switch. (see pic for reference).
I need to wipe the previous config and database for compliance/security reasons.
We dont have the password to login.
Just need to wipe the device as we dont need to retain any info from it.
Tried: to boot to Rommon and reset the device but keeps booting back up to login screen that states
"Standby Console Disabled. valid commands are: exit, logout"
Any help is greatly appreciated. Thanks.
Leo Laohoo
Password Recovery Procedure for Catalyst 4500/4000
NOTE:  The configuration file for the Catalyst 4k is found in the nvram:.
Thanks for the reply. Unfortunately the referenced link was already tried last week before i posted this.
Current output:
lax-sw-standby>?
Standby console disabled.
Valid commands are: exit, logout
Output During boot up is below:
Type control-C to prevent autobooting.
******** The system will autoboot now ********
config-register = 0x2101
Autobooting using the first file from bootflash.....
Rommon reg: 0xE2004180
k2diags version 5.7
prod: WS-X4013+ part: 73-9272-09 serial: JAE1220IAHK
Power-on-self-test for Module 3: WS-X4013+
Port/Test Status: (. = Pass, F = Fail, U = Untested)
Reset Reason: PowerUp Software/User
Cpu Subsystem Tests ...
seeprom: . temperature_sensor: . eobc: .
Port Traffic: L2 Serdes Loopback ...
0: . 1: . 2: . 3: . 4: . 5: . 6: . 7: . 8: . 9: . 10: . 11: .
12: . 13: . 14: . 15: . 16: . 17: . 18: . 19: . 20: . 21: . 22: . 23: .
24: . 25: . 26: . 27: . 28: . 29: . 30: . 31: .
Not sure what else I can do? Any ideas anyone?
