01-06-2013 11:50 PM
Dear Experts ,
Am new to cisco Scripting
I am looking for a script for configuring interface description automaticaly for connected cisco devices using EEM script for routers and switches .
switch : 3560 or 3750
Router : 2800 or 3745
Please help me to get the same configured .
Thanks in Advance
Agnus
01-07-2013 06:04 AM
Have a look at this article:
01-07-2013 10:09 PM
Dear Joseph ,
Thanks a lot for your quick response .
I am not able to find the command on my cisco 3745 router . I will try the same on Cisco 3560 switch and let you know .
Please let me know is there any script to run on cisco routers
Agnus
01-08-2013 09:51 PM
This will work on routers, but the routers need EEM 3.2 or higher. The 3745 will never support 3.2. There is no easy way to do what you want on a 3745. You would need to periodically sweep the CDP neighbor table and change descriptions accordingly. It wouldn't be as live as the example I provided, though.
