03-17-2014 03:08 PM
I hope someone can help out..
I have a WS-C3750-48PS-S switch runing Version 12.2(25r)SEC, RELEASE SOFTWARE (fc4) - I know that the IOS is very old....we have tried and failed to upgrade to a more current IOS...
I can Telnet to the switch and all is well
I can reach the switch on HTTP and use the enable password to login to the switch with my browser.
When I try to use the built in web interface I get no info.... Likely a compatbility issue since it mentions IE 6 (I'm running Win 7 and IE 9)
So.... I thought I could use Cisco Network Assistant... Tried 5.8 and then removed it and tried 4.1
Both versions said "Unsupported device"
Does anyone know of a version of CNA that IS OK with IOS 12.2?
03-17-2014 03:15 PM
03-17-2014 05:09 PM
Leo
Thanks for ther reply.... I thought so also..
I know that the specific model is support, but I still get "Unsupported device" when I try to add it to CNA?
Is it possible that the IOS version is too old?
Or maybe access level is not sufficent?
SCJ
