netflow 9 setup
moogprodigy
Community Member
hi,  Catalyst 4500 L3 Switch Software (cat4500e-ENTSERVICESK9-M), Version 15.2(1)
i want to configure netflow 9,
There is a server from which you need to collect information ,
flow exporter nat12
description NAT12
destination 10.10.0.3 (collector)
source Vlan177
does not work
but there is no command for settings on the interface, except for this command there is nothing flowcontrol
What else can I configure to work?
7 Replies 7
balaji.bandi
check out Cat 4K requirement, what supervisor is this :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/XE3-9-0E/15-25E/configuration/guide/xe-390-configuration/fnf.html
BB
Tnx, But why after  match and after ip  no flow
Switch(config-flow-record)#match ipv4 tos
% Invalid input detected at '^' marker.
% Incomplete command.
Switch(config-flow-record)#match ?
% Unrecognized command
Switch(config-if)#ip ?
Interface IP configuration subcommands:
access-group Specify access control for packets
admission Apply Network Admission Control
arp Configure ARP features
device IP Device tracking
dhcp Configure DHCP parameters for this interface
igmp IGMP interface commands
rsvp RSVP Interface Commands
verify verify
Georg Pauwen
post the output of:
show module all
Chassis Type : WS-C4900M
Power consumed by backplane : 0 Watts
Mod Ports Card Type Model Serial No.
1 8 4900M 10GE (X2) WS-C4900M JAE1707074S
2 24 10GE (X2), 1000BaseX (SFP) WS-X4908-10GE JAE15340HP5
3 20 10/100/1000BaseT (RJ45) WS-X4920-GB-RJ45 JAE150801WP
M MAC addresses Hw Fw Sw Status
1 e02f.6d15.4f00 to e02f.6d15.4f07 1.8 12.2(44r)SG1 15.2(1)E1 Ok
2 30e4.dbc1.3e84 to 30e4.dbc1.3e9b 1.2 Ok
3 e05f.b932.07cc to e05f.b932.07df 1.2 Ok
I don't think you have hardware support for Netflow. You should see something like below:
Mod Submodule Model Serial No. Hw Status
1 Netflow Services Card WS-F4531 JAB062209CG 0.2 Ok
2 Netflow Services Card WS-F4531 JAB062209AG 0.2 Ok
Thank's  , what firmware do you recommend ,now firmware
System image file is "bootflash:cat4500e-entservicesk9-mz.152-1.E1.bin"
its not about the  IOS, as per the information hardware imitation.
BB
