Prime 3.8 lost mapping data
David Ritter
Level 4
Level 4
Some time ago my instance of Prime 3.8 lost ~ about half of its mapping data.  Any means to determine when the event occurred so I can reach back and do a restore?  AP positioning's are not otherwise recorded and will be a bit difficult to recover.
balaji.bandi
Do you have application backup known or did you exported Maps any time ? that is the only way you can restore back.
BB
