Netflow Configuration on IOS 15
mlharv007
All,
First of all, this board has been instramental in helping us through a number of issues we have had in building out our new corporate headquarters.  I do have a netflow question that has got me this time.  Below is my netflow config on a set of 4, 3750's stackwise running IOS 15.  I am not getting an packet leaving the switches nor am I seeing any on my cacti server.  I have checked the server and not blocking on the iptables firewall.  Below in my config:
flow record TWI-2E-SW1
match ipv4 destination address
collect counter flows
flow exporter Cacti
description Cacti Server
destination 10.15.10.18
transport udp 2055
export-protocol netflow-v5
flow monitor Cacti
description Cacti Netflow Tool
record TWI-2E-SW1
exporter Cacti
ip flow-export version 5
ip flow-export destination 10.15.10.18 2055
ip flow-export destination 10.15.10.238 2055
interface GigabitEthernet1/1/4
description Primary East connection to TWI-DC-E1 port 7/2
switchport mode trunk
ip flow ingress
ip flow egress
ip flow monitor Cacti layer2-switched input
ip flow monitor Cacti layer2-switched output
interface GigabitEthernet4/1/4
description Secondary East connection to TWI-DC-W1 port 7/22
ip flow ingress
ip flow egress
_______________________
Show IP flow export
k
TWI-2E-SW1#sh ip flow export
Flow export v5 is enabled for main cache
  Export source and destination details :
  VRF ID : Default
    Destination(1)  10.15.10.18 (2055)
    Destination(2)  10.15.10.238 (2055)
  Version 5 flow records
  0 flows exported in 0 udp datagrams
  0 flows failed due to lack of export packet
  0 export packets were sent up to process level
TWI-2E-SW1#
Thanks again
7 Replies 7
Marvin Rhoads
The 3750 only supports NetFlow with the optional services module. Can you confirm your hardware modules and revision?
Whitepaper:
Reference.
Configuration guide:
Reference.
We are using the following:
C3KX-NM-1G=  1 GB Network Module
GLC-SX-MM=   SFP GBICS
I am looking for the revision number as well.
Revision info:
General SFP Information
Identifier            :   0x03
Connector             :   0x07
Transceiver           :   0x00 0x00 0x00 0x01 0x00 0x00 0x00 0x00
Encoding              :   0x01
BR_Nominal            :   0x0D
Vendor Name           :   CISCO-FINISAR
Vendor Part Number    :   FTLF8519P2BCL-C5
Vendor Revision       :   0x41 0x20 0x20 0x20
Vendor Serial Number  :   FNS16330EY4
I suspected as much since your configuration cites "interface GigabitEthernet1/1/4" (and 4/1/4) vs. TenGigabitEthernet x/1/x.
Only with the:
C3KX-SM-10G
Service Module with two 10GbE SFP+ ports network module for Netflow and MACsec encryption
...do you get NetFlow to work on the 3750X.
Crud, I was worried about that when I saw your whitepaper.  If I can sneak another question in, Same subject but 6500.
I have a SUP-2T-10G and want to apply on gig module blabe (WS-6724-SFP).  Am I goign to have problems.  I continue to research this to see if supported.  also, I have a vlan directly connected to my firewalls.  Can I add to vlan at minimum.
thansk as always.
You're welcome.
You should be able to setup a Netflow export on a 6509 with SUP-2T-10G. See this helpful reference:
     http://www.plixer.com/blog/cisco-netflow/catalyst-6509-netflow-support/
You could also use your firewall, assuming it's a Cisco ASA.
Please rate helpful replies.
Here is my problem.  I believe all those are for IOS 12.  I am running Version 15.0(1)SY1 on my 6500s, and having a devil of a time finding documents on this code.  I am pretty confident the commands have changed. Any docs you found that can help me.
thanks.
The source documentation for configuring Flexible NetFlow on IOS 15.0SY can be found here:
http://www.cisco.com/en/US/docs/ios-xml/ios/fnetflow/configuration/15-0sy/fnf-15-0sy-book.html
