Netflow Export Problem
efairbanks
Level 3
Level 3
I am experiencing a problem exporting netflow packets to a
network management server. The network management server resides behind a
interface on the router that is located in a MPLS VRF. I configured "ip
flow-export destination <server ip> and ip flow-export source G0/0 (the
interface in the MPLS VRF) but receive the following error when debugging ip
flow export: "Sending export pak to <netman ip address> port 9996.
Error sending export packet: Enqueued to process level". I am required
to export version 5 packets. All other routers that export out their interface
located in the global routing table do not experience this problem. Has anybody seen this before? Thanks.
smcarthur
Community Member
Have you tried exporting the data from a Loopback address? This has the advantage of data still being sent even if an interface may be down (alternate routing being available).
