Netflow Monitor not working on 3850
sysad43
Cisco IOS XE Software, Version 16.06.04
Cisco IOS Software [Everest], Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 16.6.4, RELEASE SOFTWARE (f
c3)
Hey all. Ive looked through a lot of posts, but didnt see any that helped me. Ive configured records, monitor, exporter and applied to interface on a 3850. But when I check monitor statistics, its 0
r3#show flow monitor tfb statistics
Cache type: Normal (Platform cache)
Cache size: 10000
Current entries: 0
Flows added: 0
Flows aged: 0
Here is the config, which I copied from a 3650 where its working.
flow record tfb
match ipv4 tos
match ipv4 protocol
match ipv4 source address
match ipv4 destination address
match transport source-port
match transport destination-port
match interface input
collect interface output
collect counter bytes long
collect counter packets long
collect timestamp absolute first
collect timestamp absolute last
flow exporter whatsup01
destination 10.5.200.68
transport udp 9999
flow monitor tfb
exporter whatsup01
cache timeout active 60
record tfb
interface TenGigabitEthernet1/0/12
description uplink-r1
switchport mode trunk
ip flow monitor tfb input
spanning-tree portfast disable
ip nbar protocol-discovery
Any idea what Ive done wrong?
11 Replies 11
balaji.bandi
here is the config for 3850 ( but your post also mentioned 3650 - not sure what version)
here is 3850 config
flow record tfb
match ipv4 version
match ipv4 tos
match ipv4 protocol
match flow direction
collect transport tcp flags
collect counter bytes layer2 long
source VlanXX
transport udp 9999
flow monitor tfbmonitor   <--change to monitor
exporter whatsup01
record tfb
interface TenGigabitEthernet1/0/12      <--- i was not sure it support Trunk port never tested
Any L3 / L2 intercace works
interface interface XX
ip flow monitor tfbmonitor input  <<--- <--change to monitor
Test and Advise.
BB
Thanks, but no change. Still nothing in the flow monitor. The 3650 I mentioned is also flexible netflow 9, but running ios Version 03.03.05SE. I copied the netflow config from there, where it works.
So this proves that "Cisco IOS XE Software, Version 16.06.04" not working in this version ?
BB
natuan
Hi there,
This is my configuration on C3850, I use PRTG to monitor netflow.
flow record test-record
match ipv4 protocol
match ipv4 tos
flow exporter test-export
destination x.x.x.x
source GigabitEthernet1/0/2
transport udp 2055
template data timeout 60
flow monitor test-monitor
record test-record
interface GigabitEthernet1/0/2
description >>>
no switchport
ip flow monitor test-monitor input
ip address a.b.c.d
Hope this help.
Almost exactly my setup, so it should work, but still no. Im not sure whats wrong.
Can you post show version. Full config (removing any confidential to look).
Do you have QoS Enabled ?
BB
QOS is enabled
show run
r3#show run
Building configuration...
Current configuration : 8255 bytes
! Last configuration change at 08:45:51 EDT Wed Apr 10 2019
version 16.6
no service pad
no platform punt-keepalive disable-kernel-core
hostname
vrf definition Mgmt-vrf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
clock timezone est -5 0
clock summer-time EDT recurring
switch 1 provision ws-c3850-12xs
ip routing
ip nbar http-services
flow record tfbrecord
match ipv4 tos
match ipv4 protocol
match ipv4 version
destination a.b.c.d
source Vlan1
transport udp 9999
exporter whatsup01
record tfbrecord
crypto
crypto pki certificate
quit
diagnostic bootup level minimal
spanning-tree mode rapid-pvst
username
redundancy
mode sso
class-map match-any system-cpp-police-topology-control
description Topology control
class-map match-any system-cpp-police-sw-forward
description Sw forwarding, L2 LVX data, LOGGING
class-map match-any system-cpp-default
description DHCP Snooping, EWLC control, EWCL data
class-map match-any system-cpp-police-sys-data
description Learning cache ovfl, Crypto Control, Exception, EGR Exception, NFL SAMPLED DATA, Gold Pkt, RPF Failed
class-map match-any system-cpp-police-punt-webauth
description Punt Webauth
class-map match-any system-cpp-police-l2lvx-control
description L2 LVX control packets
class-map match-any system-cpp-police-forus
description Forus Address resolution and Forus traffic
class-map match-any system-cpp-police-multicast-end-station
description MCAST END STATION
description Transit Traffic and MCAST Data
class-map match-any system-cpp-police-l2-control
description L2 control
class-map match-any system-cpp-police-dot1x-auth
description DOT1X Auth
class-map match-any system-cpp-police-data
description ICMP redirect, ICMP_GEN and BROADCAST
class-map match-any system-cpp-police-stackwise-virt-control
description Stackwise Virtual
class-map match-any non-client-nrt-class
class-map match-any system-cpp-police-routing-control
description Routing control
class-map match-any system-cpp-police-protocol-snooping
description Protocol snooping
class-map match-any system-cpp-police-system-critical
description System Critical
policy-map system-cpp-policy
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
no ip address
shutdown
speed 1000
negotiation auto
description rubrik
switchport access vlan 200
switchport mode access
interface TenGigabitEthernet1/0/2
description rubrik
interface TenGigabitEthernet1/0/3
description rubrik
interface TenGigabitEthernet1/0/4
description rubrik
interface TenGigabitEthernet1/0/5
interface TenGigabitEthernet1/0/6
interface TenGigabitEthernet1/0/7
interface TenGigabitEthernet1/0/8
interface TenGigabitEthernet1/0/9
interface TenGigabitEthernet1/0/10
interface TenGigabitEthernet1/0/11
interface TenGigabitEthernet1/1/1
interface TenGigabitEthernet1/1/2
interface TenGigabitEthernet1/1/3
interface TenGigabitEthernet1/1/4
interface Vlan1
ip address
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 600 life 180 requests 25
ip http session-idle-timeout 600
ip routes
logging trap errors
logging host
snmp-server community
control-plane
service-policy input system-cpp-policy
ntp logging
mac address-table notification mac-move
wsma agent exec
wsma agent config
wsma agent filesys
wsma agent notify
end
show ver
r3#show ver
c3)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Sun 08-Jul-18 02:57 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2018 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: CAT3K_CAA Boot Loader (CAT3K_CAA-HBOOT-M) Version 3.58, RELEASE SOFTWARE (P)
r3 uptime is 25 weeks, 2 days, 2 minutes
Uptime for this control processor is 25 weeks, 2 days, 5 minutes
System returned to ROM by Power Failure or Unknown
System image file is "flash:packages.conf"
Last reload reason: Power Failure or Unknown
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Technology Package License Information:
Technology-package Technology-package
Current Type Next reboot
ipbasek9 Permanent ipbasek9
cisco WS-C3850-12XS (MIPS) processor (revision L0) with 853093K/6147K bytes of memory.
Processor board ID
1 Virtual Ethernet interface
16 Ten Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
253984K bytes of Crash Files at crashinfo:.
3334464K bytes of Flash at flash:.
0K bytes of WebUI ODM Files at webui:.
Switch Ports Model SW Version SW Image Mode
* 1 16 WS-C3850-12XS 16.6.4 CAT3K_CAA-UNIVERSALK9 INSTALL
Configuration register is 0x102
As suggested my other post, can you move the config from Trunk port to different L2 or L3 port and test and advise.
BB
Sorry, I did try that, but still no change. Time for a TAC?
engineer467
Hello.
Did you find a solution to this problem?
No, but another admin took over and had done a bunch since then. Ive moved on.
