07-12-2018 08:12 AM - edited 03-01-2019 06:41 PM
im getting the error "The monitor does not have a valid record" as per the below when trying to assign my flow monitor to an interface. is anyone Able to shed any light? from what ive researched I cant see any issue with it
config:
STR-LAB-01-RTR-01(config-flow-record)#do sh run | s Sola flow record FR_Solarwinds match ipv4 tos match ipv4 protocol match ipv4 source address match ipv4 destination address match transport source-port match transport destination-port match interface input collect interface output collect counter bytes collect counter packets collect timestamp sys-uptime first collect timestamp sys-uptime last collect application name flow exporter FE_Solarwinds destination 10.66.56.91 source Vlan5 transport udp 2055 option interface-table option application-table flow exporter FW_Solarwinds flow monitor FM_Solarwinds exporter FE_Solarwinds cache timeout inactive 10 statistics packet protocol statistics packet size STR-LAB-01-RTR-01(config-flow-record)#int vlan 5 STR-LAB-01-RTR-01(config-if)#ip flo STR-LAB-01-RTR-01(config-if)#ip flow mon STR-LAB-01-RTR-01(config-if)#ip flow monitor FM_Solarwinds in STR-LAB-01-RTR-01(config-if)#ip flow monitor FM_Solarwinds input % Flow Monitor: Failed to add monitor to interface: The monitor does not have a valid record STR-LAB-01-RTR-01(config-if)#
Solved! Go to Solution.
07-13-2018 03:13 AM
found the typo, I hadn't applied the record to the monitor
07-13-2018 03:13 AM
