Netmanager 1.1----Customizing Physical Topology Views
acharyr123
Level 3
Level 3
I have netmanager 1.1
I have 2 queries on this:--
1. The Physical topology view is not proper..Can i customize the view based upon my requirement like Core switch, distribution switch, access switch etc so that a n/w hierarchy is maintained....
2. Can names be in plane instead of IP in Physical Topology view for easier identification purpose...
Attached is the topology that i am getting..
Rgds,
Partha
Nael Mohammad
Level 5
Level 5
1. The device topology is displayed as the way its connected in your environment and cannot be grouped .
http://www.cisco.com/en/US/docs/net_mgmt/cisco_netmanager/1.1_data/user/guide/topo.html#wp1040314
2.   Displaying IP Address or Display Name
To have devices display on the Physical Connectivity View by IP address, display name, or both, do the following:
Step 1    Select GO > Configure > Physical Connectivity View Settings.
Step 2    Check IP address, Display Name, or both.
