Network Configuration Automation - Tool suggestions.
ajay chauhan
Level 7
Level 7
Hi Guys,
I am looking for kind of tool which can genrate reports for pair of devices considering - same config on both the devices / specific fields lets say ip route part should be same on both.
My aim to make sure config for pair devices are same I know some fields we can not match i.e port numbers (not always required to be same).
I do have HPNA where you can manually compare configuration which is done based on line by line.
Also if in future if confiuration is only done on one of the device then it should send kind of alert /report.
Many thanks.
Ajay
Vinod Arya
Cisco has Cisco Prime LMS which has option to compare config or one of more devices. It archives running and startup config and also keeps several versions of running config to be compared.
You can dowload a eval copy of Cisco Prime LMS 4.2 from here :
http://www.cisco.com/cisco/software/type.html?mdfid=284259296&flowid=31102&softwareid=280775102
For details check the user guide :
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.2/user/guide/configuration/archivemgmt.html#wp1166768
Probably the other community members can share more details on any other NMS apps to achieve this.
-Thanks
Vinod
-Thanks Vinod **Rating Encourages contributors, and its really free. **
