Network management tool Cisco
Bart Kersten
Ive been looking for Cisco software to manage an entire network. Lets say i have a network with 200 switches and i want to do a mass firmware upgrade on all switches is there a Cisco product which can do this? Ive been looking at Cisco Prime but I cant find if Prime is capable of doing this.
thanks in advance.
Kind regards,
Bart
Marvin Rhoads
Yes, Cisco Prime Infrastructure can do this.
You should verify that your switch models are on the supported devices list. Many are but not every one is.
bsiapco
Hello, Bart Kersten.
Marvin is correct! Prime Infrastracture is the best solution.
http://www.cisco.com/c/en/us/products/collateral/cloud-systems-management/prime-infrastructure/datasheet-c78-733439.html
 Happy to Serve!
Barry
Hello Barry,
Please provide additional information on the Prime Infrastructure without providing your Cisco e-mail address.
One of our goals on the Cisco Support Community is to share information so that everyone in the discussion forums benefits.
Your e-mail address has been removed from this discussion.
Thank you for your understanding!
Litsa
