Network Monitor Tool
maria.melendez
In my company we are looking for a Network Monitor Tool to be able to monitor our cisco network. We have catalyst 4506, 6509 and 3750 switches.
Thanks!
Hitesh Vinzoda
Level 4
Level 4
Check the list below :
Ciscoworks LMS
HP Openview
Netcool
Whatsup Gold
Nagios
LMS has lots of module as mentioned below with
DFM > Device fault management
RME > Resource management essentials  ( Inventory soft and hard) > IOS deployment and other tasks, Config management
Campus Manager > Topology and End user tracking in Campus
IPM > internetwork performance monitor ( Using IPSLA)
HUM > Health and utilization monitor
If all the devices are Cisco, LMS is a comprehensive tool.
Hitesh Vinzoda
Pls rate useful posts
Don Jacob
Hi Maria,
Try OpManager from ManageEngine. The product has features to match or beat any similar market products and is priced lower than most. Some of the features for network monitoring are:
Availability and uptime monitoring
Traffic and Utilization monitoring
Network Device Health monitoring (Router, Switch, Firewall, wireless access points)
Network mapping
Network traffic maps
WAN RTT monitoring
VoIP monitoring
Network Configuration Management
Try OpManager from the below link:
http://www.manageengine.com/products/opmanager/download.html
ManageEngine OpManager also includes a NetFlow/sFlow monitoring Plug-In for bandwidth and traffic analysis which can monitor any flow exporting devices and give detailed reports about bandwidth usage. You can download the Plug-In from the below link:
http://www.manageengine.com/products/opmanager/network-traffic-analysis.html
Check the other OpManager Add-Ons from
http://www.manageengine.com/products/opmanager/opmanager-addons.html
OpManager also has a free edition which lets you monitor 10 devices with the basic monitoring functionality.
Don Thomas Jacob
ManageEngine
Regards, Don Thomas Jacob http://www.solarwinds.com/netflow-traffic-analyzer.aspx Head Geek @ SolarWinds NOTE: Please rate and close questions if you found any of the answers helpful.
