network stops on cisco ucs c200 m2
m-mehdipoor
I have a cisco ucs c200 m2 server which installed Esxi 6.7 on it.
Server's network stops every day and the only way to have it online again is restarting the server. I've even got KVM access from datacenter and tried to restart just the network of it but it doesn't work and again I forced to restart the server.
marce1000
 - Go to the UCS manager and have a look at : Admin > Faults, Events & Audit Log , look at Faults and Events, perhaps you will get more insights.
 M.
I can not access to it since this year as it requires flash player which adobe had already stop supporting it...
Is there any other way to investigate the issue?
 - Very difficult because that becomes  an chicken and egg problem, perhaps an old firefox version can still do this. If business critical then replace the server, by modern and current-supported hardware.
 M.
