Nexus 7710 SCP Failure
Attempting to move a gzip file from my Nexus 7710 to a Linux machine on my network...
#copy bootflash:File.txt.gz scp:
Enter vrf (If no input, current vrf 'default' is considered):
Enter hostname for the scp server: 192.168.0.1
Enter username: user
no matching mac found: client hmac-sha1,hmac-sha1-96 server hmac-sha2-256, hmac-sha2-512
lost connection
Enter username: /user
cp: cannot create regular file `/user@192.168.0.1:File.txt.gz': Permission denied
Enter hostname for the scp server: //192.168.0.1
cp: cannot create regular file `user@//192.168.0.1:File.txt.gz': No such file or directory
None of these variations have given a successful result.
balaji.bandi
First check do you have that in file bootflash:  by issue dir command
try below syntax
copy bootflash:File.txt.gz scp://username:password@x.x.x.x/   <<- this will copy to user folder
BB
dir command helped me confirm the file is in bootflash. Your syntax resulted in the error from scenario 1...
lost connection
I typed the Enter key at the vrf line without giving any input. Is that a problem?
balaji.bandi
can you able to ping SCP Server with out input any VRF, then default VRF should be ok.
can you show us the results of ping x.x.x.x post here.
what kind of SCP server on far end ?
BB
