Nexus 9000 Netflow
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
08-12-2023 04:44 AM
I am configuring the netflow on my Nexus:
Hardware
cisco Nexus9000 C93180YC-FX Chassis
Intel(R) Xeon(R) CPU D-1528 @ 1.90GHz with 24569704 kB of memory.
I am using these commands:
flow exporter PRTG-Exporter
destination 10.2.58.106 use-vrf KIS-ADM
source vlan410
version 9
template data timeout 20
flow record PRTG-Record
match ipv4 source address
match ipv4 destination address
collect counter bytes
collect counter packets
flow monitor PRTG-Monitor
record PRTG-Record
interface Ethernet1/5
ip flow monitor foo input
The problem is that interface Ethernet 1/5 does not have Flow command:
Here is the ETH1/5 running configuration:
description Internet
switchport
switchport access vlan 3
spanning-tree port type edge
no shutdown
What do i miss here?!
- Labels:
Network Management
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-12-2023 09:10 AM - edited 08-12-2023 09:12 AM
Hello @Moudar,
NetFlow monitoring is typically performed on routed interfaces or Layer 3 interfaces.
You'll need to change the configuration to make it a routed interface.
no switchport
--> interface Ethernet1/5
ip address <IP_ADDRESS> <SUBNET_MASK>
Configure the NetFlow monitor on that interface:
ip flow monitor PRTG-Monitor input
-> no "foo" but your Monitor configured.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-12-2023 10:43 AM
This interface must not be routed, it should be a trunk. So L2 Netflow is possible I think
When I check the documentaions of Nexus switches I see:
Do these commands affect the overall efficiency of that port. I don't want to cut the internet for 4000 people
What info should L2 Netflow show?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-12-2023 11:18 AM - edited 08-12-2023 11:06 PM
OK @Moudar
What about the name of your Monitor on your interface... foo? No PRTG-Monitor?
If yes, ensure that the configuration in PRTG matches the settings you've provided for the flow exporter and monitor. Double-check IP addresses, ports, and other settings...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-12-2023 03:36 PM
Now it looks like this:
transport udp 2055
source Vlan410
version 9
match datalink ethertype
record PRTG-Record
The switch is like this:
Nexus-1# sh flow exporter PRTG-Exporter
Flow timeout 10
Flow exporter PRTG-Exporter:
Destination: 10.2.58.106
VRF: KIS-ADM (1)
Destination UDP Port 2055
Source Interface Vlan410 (10.32.0.251)
Export Version 9
Sequence number 2432
Data template timeout 20 seconds
Exporter Statistics
Number of Flow Records Exported 2649
Number of Templates Exported 813
Number of Export Packets Sent 2433
Number of Export Bytes Sent 110532
Number of Destination Unreachable Events 0
Number of No Buffer Events 0
Number of Packets Dropped (No Route to Host) 0
Number of Packets Dropped (other) 0
Number of Packets Dropped (LC to RP Error) 0
Number of Packets Dropped (Output Drops) 0
Time statistics were last cleared: Never
But PRTG still not getting the flows. When checking the Nexus IP on Wireshark i could see CFLOW packets come as expected:
And the Netflow sensor grayed out:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-12-2023 11:03 PM
Hello @Moudar,
The pcap wireshark is where the Netflow server is installed ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-12-2023 11:59 PM
Correct, where PRTG is installed!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-13-2023 12:32 AM
Then check PRTG configuration regarding your flow Exporter configuration.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-13-2023 01:49 AM
As you can see, everything is running as expected. only Netflow is not! I tried to add IPFIX but still grayed out
So I don't know what to do. I have same problem with Cisco WLC, the netflow is grayed out.
I have many switches and routers and these are sending Netflow traffic and working without any problem
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-13-2023 12:55 PM - edited 08-13-2023 01:00 PM
What is N9k firmware version please?
Also, you don't have a sampler configured?
You confirm you modify this?
interface Ethernet1/5 ip flow monitor foo input
By this --ip flow monitor PRTG-Monitor input
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-13-2023 01:12 PM
Software
BIOS: version 05.39
NXOS: version 9.3(2)
BIOS compile time: 08/30/2019
NXOS image file is: bootflash:///nxos.9.3.2.bin
NXOS compile time: 11/4/2019 12:00:00 [11/04/2019 23:13:33]
The interface eth 1/5 does not have the ip flow command as I mentioned before
This is how running configuration of eth1/5 looks like:
switchport
mac packet-classify
layer2-switched flow monitor PRTG-Monitor input
no shutdown
commands:
mac packet-classify layer2-switched flow monitor PRTG-Monitor input
are used to gather L2 Netflow, the problem is that PRTG is not showing anything!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-13-2023 01:20 PM - edited 08-13-2023 01:49 PM
Thanks @Moudar,
Share please the output of that command:
#show hardware flow ip
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-13-2023 01:31 PM
There is no command show hardware ip flow!
Nexus-1# show hardware flow etrap
slot 1
Elephant Flows
Unit:Slc Index:Type Source Address
Destination Address Ports(Src:Dst) Proto Approx_Rate
Index- Index in table. Type- 0:CE, 1:FCoE, 2:IPv4, 3:IPv6.
Nexus-1# sh hardware ?
<CR>
> Redirect it to a file
>> Redirect it to a file in append mode
access-list Access Control List
capacity Resource inventory and/or usage level
feature-capability Show registered features supported
flow Traffic flow information
forwarding Show hardware information for forwarding path
internal Show hardware internal information
mac MAC configuration commands
profile Profile settings
qos Show qos related information
rate-limiter Show Rate-Limiter configs and statistics
| Pipe command output to filter
sh hardware flow ?
etrap Elephant Trap information
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-13-2023 01:52 PM
It is show hardware flow ip
Feature netflow is activated?
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-12-2023 09:40 AM
I send you private message
