Bookmark
Subscribe
2160
Nexus 9000 Netflow
Moudar
I am configuring the netflow on my Nexus:
Hardware
  cisco Nexus9000 C93180YC-FX Chassis
  Intel(R) Xeon(R) CPU D-1528 @ 1.90GHz with 24569704 kB of memory.
I am using these commands:
flow exporter PRTG-Exporter
 destination 10.2.58.106 use-vrf KIS-ADM
 source vlan410
 version 9
 template data timeout 20
flow record PRTG-Record
 match ipv4 source address
 match ipv4 destination address
 collect counter bytes
 collect counter packets
flow monitor PRTG-Monitor
 record PRTG-Record
interface Ethernet1/5
 ip flow monitor foo input
The problem is that interface Ethernet 1/5 does not have Flow command:
Here is the ETH1/5 running configuration:
  description Internet
  switchport
  switchport access vlan 3
  spanning-tree port type edge
  no shutdown
What do i miss here?!
15 Replies 15
M02@rt37
Hello @Moudar,
NetFlow monitoring is typically performed on routed interfaces or Layer 3 interfaces.
You'll need to change the configuration to make it a routed interface.
no switchport
--> interface Ethernet1/5
ip address <IP_ADDRESS> <SUBNET_MASK>
Configure the NetFlow monitor on that interface:
ip flow monitor PRTG-Monitor input
-> no "foo" but your Monitor configured.
Best regards
This interface must not be routed, it should be a trunk. So L2 Netflow is possible I think
When I check the documentaions of Nexus switches I see:
Do these commands affect the overall efficiency of that port. I don't want to cut the internet for 4000 people
What info should L2 Netflow show?
OK @Moudar
What about the name of your Monitor on your interface... foo? No PRTG-Monitor?
If yes, ensure that the configuration in PRTG matches the settings you've provided for the flow exporter and monitor. Double-check IP addresses, ports, and other settings...
Best regards
Now it looks like this:
  transport udp 2055
  source Vlan410
  version 9
  match datalink ethertype
  record PRTG-Record
The switch is like this:
Nexus-1# sh flow exporter PRTG-Exporter
Flow timeout 10
Flow exporter PRTG-Exporter:
    Destination: 10.2.58.106
    VRF: KIS-ADM (1)
    Destination UDP Port 2055
    Source Interface Vlan410 (10.32.0.251)
    Export Version 9
        Sequence number 2432
        Data template timeout 20 seconds
    Exporter Statistics
        Number of Flow Records Exported 2649
        Number of Templates Exported 813
        Number of Export Packets Sent 2433
        Number of Export Bytes Sent 110532
        Number of Destination Unreachable Events 0
        Number of No Buffer Events 0
        Number of Packets Dropped (No Route to Host) 0
        Number of Packets Dropped (other) 0
        Number of Packets Dropped (LC to RP Error) 0
        Number of Packets Dropped (Output Drops) 0
        Time statistics were last cleared: Never
But PRTG still not getting the flows. When checking the Nexus IP on Wireshark i could see CFLOW packets come as expected:
And the Netflow sensor grayed out:
Hello @Moudar,
The pcap wireshark is where the Netflow server is installed ?
Best regards
Correct, where PRTG is installed!
@Moudar
Then check PRTG configuration regarding your flow Exporter configuration.
Best regards
As you can see, everything is running as expected. only Netflow is not! I tried to add IPFIX but still grayed out
So I don't know what to do. I have same problem with Cisco WLC, the netflow is grayed out.
I have many switches and routers and these are sending Netflow traffic and working without any problem
@Moudar,
What is N9k firmware version please?
Also, you don't have a sampler configured?
You confirm you modify this?
By this --ip flow monitor PRTG-Monitor input
Thanks.
Best regards
Software
  BIOS: version 05.39
 NXOS: version 9.3(2)
  BIOS compile time:  08/30/2019
  NXOS image file is: bootflash:///nxos.9.3.2.bin
  NXOS compile time:  11/4/2019 12:00:00 [11/04/2019 23:13:33]
The interface eth 1/5 does not have the ip flow command as I mentioned before
This is how running configuration of eth1/5 looks like:
  switchport
  mac packet-classify
  layer2-switched flow monitor PRTG-Monitor input
  no shutdown
commands:
mac packet-classify
are used to gather L2 Netflow, the problem is that PRTG is not showing anything!
Thanks @Moudar,
Share please the output of that command:
#show hardware flow ip
Best regards
There is no command show hardware ip flow!
Nexus-1# show hardware flow etrap
slot  1
                                                     Elephant Flows
Unit:Slc Index:Type  Source Address
 Destination Address                     Ports(Src:Dst)  Proto  Approx_Rate
 Index- Index in table. Type- 0:CE, 1:FCoE, 2:IPv4, 3:IPv6.
Nexus-1# sh hardware ?
  <CR>
  >                   Redirect it to a file
  >>                  Redirect it to a file in append mode
  access-list         Access Control List
  capacity            Resource inventory and/or usage level
  feature-capability  Show registered features supported
  flow                Traffic flow information
  forwarding          Show hardware information for forwarding path
  internal            Show hardware internal information
  mac                 MAC configuration commands
  profile             Profile settings
  qos                 Show qos related information
  rate-limiter        Show Rate-Limiter configs and statistics
  |                   Pipe command output to filter
sh hardware flow ?
  etrap  Elephant Trap information
@Moudar
It is show hardware flow ip
Feature netflow is activated?
Thanks.
Best regards
I send you private message
