Nexus 9300 - TCL or EEM script match TRACK status and do action
Mate Grbavac
I need to create EEM or TCL scrript (or combination) which will shutdown (or remove VLAN from) particular interface, but before that it need to chech status of tracked object (or SLA).
If status of TRACK is UP than script need to shutdown interface, a if status of TRACK is DOWN script should do nothing.
I have no much hands on with TCL and EEM and I belive that someone who is familiar can solve this quickly...
BR, Mate
Mark Malone
You might want to move this to the EEM section  , if you search there too there probably is very similar scripts already built you could tweak for yourself
tnx for hint, I moved conversation.
