wsma
lkadlik
Level 4
Level 4
I removed the following configuration lines from my new 3650 config:
no wsma agent conf
no wsma agent config
no wsma agent exec
no wsma agent filesys
no wsma agent notify
no wsma id
no wsma dhcp
no wsma agent
no wsma agent exec
no wsma profile listener httplistener
no wsma profile listener httpslistener
Is there anything else I need to do in order to make sure wsma is disabled?
Also, on the 3650 switches is this service used for http/https management of the switch only?
Thank you
0 Replies 0
