02-13-2017 05:32 AM
In a customers PI3.1.4 the 93180 comes up as "not supported device", although it says here that 9K should be supported:
http://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-1/user/guide/pi_ug/maint_images.html
On the other hand, in the compatibility information about Cisco Prime Infrastructure 3.1 Supported Devices:
http://www.cisco.com/c/dam/en/us/td/docs/net_mgmt/prime/infrastructure/3-1/supported/devices/PI31-Supported-Device-List.xlsx
I cannot find the 93180 listed (not even in DP7)...
Do I have to wait until DP8, and is there any way to know when DP8 will be released?
03-26-2019 07:38 AM
03-10-2020 04:32 AM
Yep - still not supported on a new customer installation of PI 3.7 with DP 1.
Looks like we are out of luck with this product line and Prime Infrastructure.
..now where was the Solarwinds sales rep's address?
04-08-2020 01:27 PM
No N9K-C93180YC-EX on the list of Supported devices in Prime 3.8.
04-08-2020 09:36 PM
It appears Cisco has decided not to add any new Nexus device support into Prime Infrastructure going forward.
12-09-2020 01:05 AM
Still not supported in 3.6 device 1, i wonder if 3.8 is supported. anyone?
12-09-2020 02:40 AM
No. The current latest release (3.8.1 with Device Pack 1) still does not support it.
As I mentioned back in April, "It appears Cisco has decided not to add any new Nexus device support into Prime Infrastructure going forward."
02-08-2021 04:11 PM
Well I am new and using a trial of Prime 3.9 and I can tell you its still not supported. This may be a deal breaker
02-08-2021 11:38 PM
Hey guys,
There will be no support anymore for Nexus in Prime, not yet and not in the next Prime Versions until it will be EOL.
For Nexus, DCNM is the given management platform. It works very good with Nexus, even if you are using classic lan design (l2 or l3 withou VXLAN or ACI).
/danny
02-09-2021 03:14 PM
Whats really annoying is Prime is supposed to be a single pane of glass, not a single pain of glass. I just want it to pull SNMP data from the Nexus, show me utilization etc. I dont need it to configure, but I want to see the data. With Prime I can only monitor the port that the Nexus connects to on the distribution/core level.
02-15-2021 12:52 PM
Nexus devices are not supported by Cisco Prime Infrastructure anymore.
Here is the EOL article
The advise is to migrate to DCNM
