Nexus and 2960g connect issue
Hi All
I am having issue while connect the cisco 2960G and nexus 5000, i have attached the network setup. so kinldy check and update how i can proceed further.
Sudharsan.R
91+8220088865
Hi Sudharsan,
Nice working with you again
So, your issue is that the 2960 switches are seeing the Nexus device as one. What you have to do is to create a port-channel between the 2960 and nexus devices. That should solve your problem.
Hi Sudharsan,
Oleksandr Nesterov
Hi sudharsan
Please share details of your installation.
What exactly problem do you have - logs, errors. How many nexus 5000, what configuration from n5k side and from cat2960
There are plenty of possible reasons and we need to narrow down the possible cause.
