Bookmark
Subscribe
2229
Nexus passwordless SFTP copy with public key not working
PatrickOS
I have a Nexus 9000 and unfortunately can't use Prime for management. I want to copy the current configuration to a sftp server using passwordless public key authentication. I have configured a local user without a password and generated a public/private key pair for it, like described in Chapter: Configuring SSH and Telnet. I have copied the public key to the sftp server and now try to use the following command to copy the configuration
copy running-configuration scp://nw_backup@nwbackup.example.com/backup/config.txt vrf default
But it's asking for a password. I can also see in the sftp server debug logs that the client doesn't use public key authentication. I have copied the private key to my desktop and can login with it without entering a password.
Nexus9# show username nw_backup keypair
rsa Keys generated:Thu Jan 24 14:12:46 2019
ssh-rsa AAAA...Oxsew==
bitcount:262144
fingerprint:
MD5:d3:ad:6f:7...:d5:23
could not retrieve dsa key information
  System version: 7.0(3)I6(1)
What is the problem? Do I have to set a local password for the account or is it not allowed to use an _ in the username? The copy works, if I enter the password for the user on the sftp server.
Patrick
matdan16
Hi @PatrickOS ,
I just want to check if you found a way do it
Thank you.
