10-12-2010 12:49 PM
The NME-WAE-502-K9 shows as an unknown device type in RME. The SysObjectID returns as .1.3.6.1.4.1.9.1.1210; however, the RME supported device table says it should be 1.3.6.1.4.1.9.1.823. I have confirmed the device credentials are correct. The inventory & config archive are working. What do I need to do to ensure RME recognizes the NM correctly?
Solved! Go to Solution.
10-14-2010 04:56 PM
Hi Drew,
Very interesting. I'm actually working with another customer at present who has both nme-wae-502 and nme-wae-522 devices, and both of these are returning sysObjectID 1.3.6.1.4.1.9.1.823 (ciscoNmWae) , which according to the LMS 3.2 Supported Devices documentation is correct - http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.2/device_support/table/lms32sdt.html.
In my investigation of this other problem I did come across 1.3.6.1.4.1.9.1.1210 (ciscoNmWae502) & 1.3.6.1.4.1.9.1.1211 (ciscoNmWae522) but couldn't explain why the different sysObjectID's
From my customer I see :
Cisco Wide Area Application Services Software Hardware Version: nme-wae-502-4.0.23.4
Cisco Wide Area Application Services Software Software Release 4.0.23 (build b4 Apr 20 2009)
AND
Cisco Wide Area Application Services Software Hardware Version: nme-wae-522-4.1.3a.32
Cisco Wide Area Application Services Software Software Release 4.1.3a (build b32 Jun 18 2009)
You are seeing :
Cisco Wide Area Application Services (WAAS-UNIVERSAL-K9) Software Release 4.2.1 (build b38 Jun 16 2010)
Version: nme-wae-502-4.2.1.38
So what I think has happened here, is that in the later release of WAE software that you are running, the new sysObjectID's have been introduced to uniquely identify the nme-wae-502 and nme-wae-522. Unfortunately these new sysObjectID's are not recognised by LMS/RME hence it's showing as an Unknown device type in RME.
I'll need to lodge a request to have support for these new sysObjectID's added to LMS. Not sure how long this will take before it becomes available though.
Derek
10-13-2010 09:48 PM
Update the MDF version and the device packages from Ciscoworks LMS --> Common Services --> Software Center --> Device Update and select RME then download and install the updates.
And then let me know the results and post the WAE version number if the problem persists.
10-14-2010 06:29 AM
Hello & thank you for the response. That was the first thing I did when I noticed this problem. Now if I do a "check for updates" I am presented with a pop-up box that states: "All the available package(s) at source location are already installed." Here are the version details. Let me know if you need anything else.
CS:
DeviceData: 1.8
Mdf: 1.43
RME:
SysObjectID: 1.3.6.1.4.1.9.1.823
Device Name: Cisco Wide Area Application Services Network Module(NME-WAE-502)
Package Name: CE500
Version: 6.1
NME-WAE-502:
Cisco Wide Area Application Services Software (WAAS)
Copyright (c) 1999-2010 by Cisco Systems, Inc.
When doing an SNMP walk of the above device (NME-WAE-502), the SysObjectID: is returned as1.3.6.1.4.1.9.1.1210.
Thank you,
Drew
10-14-2010 04:56 PM
Hi Drew,
AND
You are seeing :
Derek
10-14-2010 09:18 PM
Hi Drew,
I submitted the requests for support for .1.3.6.1.4.1.9.1.1210 (ciscoNmWae502) & .1.3.6.1.4.1.9.1.1211 (ciscoNmWae522) to be added. Developers have advised that this should be available in about a months time
Derek
10-15-2010 05:37 AM
Derek,
I figured that had to be the case. Thank you for looking into this & submitting for the OIDs to be added to the device package. I will watch for the updates.
Drew
