NMS Upgrade Paths.
tauseef
Hi All,
I have a Plan to implement 2 Network Management Solutions.
1st Solution Qurey:
Cisco WAN Manager (CWM) on a solaris machine running CWM 9.2
I have ordered for a CWM-15.0.00JU=CWM Server Major Upgrade to R15.0.00
This is case of the following note on Cisco Site.
# Cisco WAN Manager 9.x customers who do not use the Cisco Service
Agent need only purchase the Cisco WAN Manager Server Major Upgrade.
I would be installin this on a New Solaris 9.0 Machine,
Question is:
For the product that I have bought, will I have to first install 9.2 and
then upgrade it to 11.0 and then to 15.0 Cause cisco site says the following
*CWM Release 15 can be upgraded from the following releases. Upgrading implies that the existing databases can be converted and used in the upgraded version.
? CWM Release 11.0.10 (latest patch) both Solaris 7 and Solaris 8 versions.
? CWM Release 12.0.10 (latest patch).
To upgrade to CWM Release 15, users of earlier CWM releases must first upgrade to one of the releases
listed above.
OR
Is it a direct install product, as its a fresh installation on a new server
and same Solaris platform. ??
2nd Solution Query:
I have solaris again running Cisco Works 2000 ( LMS 2.2 ) I have bought a product CWLMS-2.5-RUP-K9 = Upgrade for CiscoWorks
LMS 2.5 Enterprise customers wanting to convert to LMS 2.5 Large Enterprise for Windows and Solaris with unrestricted
device-usage license and one server-installation license
But this I want to install on a Windows Server 2003.
Will I have to again install Cisco Works 2000 first on Windows Server 2003 and
then upgrade it to LMS 2.5
OR
Is it again a direct install on to Windows 2003 server as its again a fresh
install on a new server and new windows platform. ??
Thanks in advance for your inputs.
Rgds.
Tauseef Ahmed.
David Stanford
For the LMS 2.5 portion I would go ahead and install clean on the Windows 2003 server. Once installed go ahead and upgrade the service packs to the latest (LMS 2.6 has been released on CCO)
