'no vstack' command persist after reboot ?
mediaworksnz
Level 2
Level 2
We just had a security audit and they told us that some of our switches still had vstack enabled.
Models:
WS-C3560X-48
WS-C2960CG-8TC-L
I am trying to understand why this would be, as I had previously added the command 'no vstack' to all switches. I did have some switches that would not take the command 'no vstack' but when I checked via 'sh vstack config' they showed the Vstack Director IP address as 0.0.0.0 which I thought meant that vstack was disabled.
Therefore, does the following output mean that vstack is disabled ?
mySwitch(config)#do sh vstack config
Role: Client
Vstack Director IP address: 0.0.0.0
or is it essential that you see the words '(SmartInstall disabled)' i.e.:
switch# show vstack config
Role: Client (SmartInstall disabled)
johnd2310
Level 11
Level 11
What switch model do you have?  If vstack is disabled, the operational  mode should be disabled and role should be N/A
e.g.
*3850*
sh vstack config
Capability: Director | Client
Oper Mode: Disabled
Role: NA
*3560*
sh vstack config
Oper Mode: Disabled
Role: NA
John
**Please rate posts you find helpful**
Hello, the models are:
WS-C3560X-48
WS-C2960CG-8TC-L
What exactly do I need to do to disable vstack.
With these models either the command 'no vstack' cannot be entered or it is already entered but the following shows up:
Role: Client
 The command "no vstack" should work for those switches and it should persistence after a reload. "show vstack config" should display the following output when  vtack is disabled on 2960 and 3560x running 15.0(2)SE9:
sh vstack config
John
Leo Laohoo
The command "no vstack" should persist as long as the configuration is saved.
