NTP - clock unsynchronized
istvan.kelemen1
Hello Guys,
Why it is showing as unsynchronized? Could you please recommend me any free NTP server? Thx.
I have also tried with :
0.ch.pool.ntp.org
VOICE_1#show ntp associations
  address         ref clock       st   when   poll reach  delay  offset   disp
  192.168.0.2     192.168.0.1      2     44     64     1  5.423 1046323 7937.5
 ~134.170.185.211 10.20.229.51     2     35     64     1 173.43 52356.2 7945.3
  192.168.0.252   192.168.0.1      2     19     64     1  1.157 1046324 7937.7
  192.168.0.253   192.168.0.1      2      7     64     1  1.849 1046319 7937.8
  192.168.0.254   192.168.0.1      2     25     64     1  2.910 1046322 7937.6
 * sys.peer, # selected, + candidate, - outlyer, x falseticker, ~ configured
VOICE_1#show ntp status
Clock is unsynchronized, stratum 16, no reference clock
nominal freq is 250.0000 Hz, actual freq is 249.9933 Hz, precision is 2**24
reference time is D899CF76.87BD1EC1 (17:59:34.530 GTM+1 Thu Feb 26 2015)
clock offset is 0.0000 msec, root delay is 0.00 msec
root dispersion is 4.47 msec, peer dispersion is 0.00 msec
loopfilter state is 'CTRL' (Normal Controlled Loop), drift is 0.000026765 s/s
system poll interval is 64, last update was -739 sec ago.
VOICE_1#sh run | s ntp
ntp server time.windows.com
Leo Laohoo
Never use a Windows device as an NTP source.  Microsoft's implementation of NTP is not of the IEEE standard.
If you want an outside NTP source, make sure your firewall allows you to.   Worldwide NTP pools can be found HERE
thx, but the problem was: I did not wait long enough :)
