10-23-2018 08:36 AM
In general, how are HVAC systems (if any one has implemented HVAC systems) like. Are they multiple systems (lets assume in a factory or a building) each requiring an IP, if yes then how many systems are combined together, (I have no knowledge of HVAC systems and was not able to find how many "devices" are there in HVAC system that can be assigned an IP) or are they 1 single system with just 1 IP (I doubt its just 1 system) ?
Thank You
Solved! Go to Solution.
10-25-2018 06:31 AM
I'm not an HVAC expert, but have been exposed to some that needed network connectivity for monitoring and control. I don't think there is a set answer to your question and that it all depends on the system itself. It's been my experience that there are generally central control unit(s), plus panels at certain locations that can run multiple units and in some cases a single panel for a single unit. Some require IP, others just use proprietary controls outside of IP.
So it all depends. Your best bet is not to try and figure out what you need based on no real information, but to have the information presented to you and then design the network accordingly.
Hope this helps.
10-25-2018 06:31 AM
Hope this helps.
