OID Number Extension
Toss Leey
I used OID: 1.3.6.1.4.1.9.9.109.1.1.1.1.24 to retrieve CPU value; and cisco device return to me same OID with extension, my question is how i can know .1, .2, .7 and .9 belong to what CPU?
1.3.6.1.4.1.9.9.109.1.1.1.1.24.1  = Gauge32: 2
1.3.6.1.4.1.9.9.109.1.1.1.1.24.2  = Gauge32: 0
1.3.6.1.4.1.9.9.109.1.1.1.1.24.7  = Gauge32: 0
1.3.6.1.4.1.9.9.109.1.1.1.1.24.9  = Gauge32: 0
Ben Walters
Level 4
Level 4
Those values are found in another MIB entPhysicalName
1.3.6.1.2.1.47.1.1.1.1.7.1
1.3.6.1.2.1.47.1.1.1.1.7.2
1.3.6.1.2.1.47.1.1.1.1.7.7
1.3.6.1.2.1.47.1.1.1.1.7.9
Should tell you which CPUs they are.
I found these values, it look like not related to any CPU type such as RP1, RP0, ESP0,SIP0?
1.3.6.1.2.1.47.1.1.1.1.7.1        Chassis
1.3.6.1.2.1.47.1.1.1.1.7.2        slot 0
1.3.6.1.2.1.47.1.1.1.1.7.7        slot F0
1.3.6.1.2.1.47.1.1.1.1.7.9        Power Supply Bay 0
