05-27-2024 02:06 AM
CCTV camera not working properly ,,, frequently disconnecting.
it's connected with cisco access switch
05-27-2024 02:08 AM
What is the model of the switch?
What is the firmware of the switch?
05-27-2024 02:13 AM
cisco WS-C3650-48PS (MIPS) processor with 4194304K bytes of physical memory.
Processor board ID FDO1903E0EU
4 Virtual Ethernet interfaces
52 Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
250456K bytes of Crash Files at crashinfo:.
1609272K bytes of Flash at flash:.
0K bytes of Dummy USB Flash at usbflash0:.
0K bytes of at webui:.
Base Ethernet MAC Address : 74:a2:e6:f7:11:00
Motherboard Assembly Number : 73-15131-05
Motherboard Serial Number : FDO19030PVN
Model Revision Number : D0
Motherboard Revision Number : A0
Model Number : WS-C3650-48PS
System Serial Number : FDO1903E0EU
Switch Ports Model SW Version SW Image Mode
* 1 52 WS-C3650-48PS 03.06.00E cat3k_caa-universalk9 INSTALL
Configuration register is 0x102
has context menu
05-27-2024 02:15 AM
May 27 2024 12:12:28.445 AST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/38, changed state to down
May 27 2024 12:12:30.445 AST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/38, changed state to up
May 27 2024 12:12:41.888 AST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/36, changed state to down
May 27 2024 12:12:43.887 AST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/36, changed state to up
May 27 2024 12:12:55.287 AST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/38, changed state to down
May 27 2024 12:12:57.286 AST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/38, changed state to up
May 27 2024 12:13:08.798 AST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/36, changed state to down
May 27 2024 12:13:09.468 AST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/38, changed state to down
May 27 2024 12:13:10.799 AST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/36, changed state to up
May 27 2024 12:13:11.466 AST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/38, changed state to up
May 27 2024 12:13:14.047 AST: %DOT1X-5-FAIL: Authentication failed for client (0006.6840.2afa) on Interface Gi1/0/2 AuditSessionID AC12C3A20000590E5A28B144
May 27 2024 12:13:14.067 AST: %MAB-5-FAIL: Authentication failed for client (0006.6840.2afa) on Interface Gi1/0/2 AuditSessionID AC12C3A20000590E5A28B144
May 27 2024 12:13:23.086 AST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/36, changed state to down
May 27 2024 12:13:25.088 AST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/36, changed state to up
May 27 2024 12:13:27.439 AST: %DOT1X-5-FAIL: Authentication failed for client (0050.1a38.78a2) on Interface Gi1/0/38 AuditSessionID AC12C3A20000669663E44B9E
May 27 2024 12:13:40.838 AST: %DOT1X-5-FAIL: Authentication failed for client (0050.1a38.78f2) on Interface Gi1/0/36 AuditSessionID AC12C3A20000669763E480E6
May 27 2024 12:14:03.406 AST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/38, changed state to down
May 27 2024 12:14:05.409 AST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/38, changed state to up
May 27 2024 12:14:24.565 AST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/36, changed state to down
May 27 2024 12:14:26.565 AST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/36, changed state to up
May 27 2024 12:14:30.266 AST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/38, changed state to down
May 27 2024 12:14:30.276 AST: %DOT1X-5-FAIL: Authentication failed for client (0006.6840.2afa) on Interface Gi1/0/2 AuditSessionID AC12C3A20000590E5A28B144
May 27 2024 12:14:30.300 AST: %MAB-5-FAIL: Authentication failed for client (0006.6840.2afa) on Interface Gi1/0/2 AuditSessionID AC12C3A20000590E5A28B144
May 27 2024 12:14:32.265 AST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/38, changed state to up
May 27 2024 12:14:44.515 AST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/38, changed state to down
May 27 2024 12:14:46.526 AST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/38, changed state to up
May 27 2024 12:14:51.478 AST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/36, changed state to down
May 27 2024 12:14:53.476 AST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/36, changed state to up
PEARL-QATAR-DIST-SW#
has context menu
05-27-2024 02:17 AM
And which port is the CCTV connected to?
05-27-2024 02:24 AM
we have 2 Cameras
if I connect with another switch , it's working fine
I change the port in same witch (with working one) also the same issue
Mac address whitelisted
cable ok and the camera ok
05-27-2024 02:27 AM
Do the following
test cable tdr interface G1/0/36
test cable tdr interface G1/0/38
Wait for about 15 seconds and then continue with the following commands:
show cable tdr interface G1/0/36
show cable tdr interface G1/0/38
sh interface G1/0/36
sh interface G1/0/38
05-27-2024 02:47 AM
PEARL-QATAR-DIST-SW#show cable tdr int gi1/0/38
TDR test last run on: May 27 12:39:22
Interface Speed Local pair Pair length Remote pair Pair status
Gi1/0/38 100M Pair A 0 +/- 1 meters Pair B Normal
Pair B 0 +/- 1 meters Pair A Normal
Pair C 14 +/- 1 meters N/A Short
Pair D 15 +/- 1 meters N/A Short
PEARL-QATAR-DIST-SW#test cable tdr int gi1/0/36
Link state may be affected during TDR test
TDR test started on interface Gi1/0/36
A TDR test can take a few seconds to run on an interface
Use 'show cable-diagnostics tdr' to read the TDR results.
PEARL-QATAR-DIST-SW#show cable tdr int gi1/0/36
TDR test last run on: May 27 12:41:51
Gi1/0/36 100M Pair A 0 +/- 1 meters Pair B Normal
Pair C 16 +/- 1 meters N/A Short
Pair D 17 +/- 1 meters N/A Short
PEARL-QATAR-DIST-SW#sh int gi1/0/36
GigabitEthernet1/0/36 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 74a2.e6f7.1124 (bia 74a2.e6f7.1124)
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:00:16, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 1000 bits/sec, 1 packets/sec
5 minute output rate 1000 bits/sec, 2 packets/sec
485373 packets input, 83617098 bytes, 0 no buffer
Received 71337 broadcasts (57405 multicasts)
0 watchdog, 57405 multicast, 0 pause input
1503843 packets output, 141872175 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
PEARL-QATAR-DIST-SW#sh int gi1/0/38
GigabitEthernet1/0/38 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 74a2.e6f7.1126 (bia 74a2.e6f7.1126)
Last input 00:00:35, output never, output hang never
592798 packets input, 129831736 bytes, 0 no buffer
Received 318687 broadcasts (206164 multicasts)
0 watchdog, 206164 multicast, 2 pause input
1255602 packets output, 128311300 bytes, 0 underruns
0 output errors, 0 collisions, 7 interface resets
has context menuComposeParagraph
05-27-2024 03:13 AM
I think the cameras are failing.
05-27-2024 02:29 AM
check storm control level you see in port
MHM
05-27-2024 04:20 AM
noted with thanks
I advise to replace the camera to CCTV Team.
