Password reset for LMS
vaibhav-g
plse let me know the procedure of resetting admin password of login page.
Vaibhav
Joe Clarke
You can run the NMSROOT/bin/resetpasswd utility to reset an LMS user's password.
Once again~
YOU ARE AWESOOOOOMMMMEEEE!
KG
when i am running resetpasswd admin am getting the following error,
ld.so.1: resetpasswd: fatal: libcrypto.so.0.9.8: open failed: No such file or directory
Killed
Bala
You need to set your LD_LIBRARY_PATH prior to running resetpasswd:
env LD_LIBRARY_PATH=/opt/CSCOpx/lib:/opt/CSCOpx/MDC/lib /opt/CSCOpx/bin/resetpasswd
If you have further problems, please start a new thread.
