Pb java with LMS 4.0
lbellicaud
I have install LMS4.0 on server 2008r2 64bits.
When i use ie 32bits, topology does not work.
when using ie 64-bit same problem
thanks for your response
Go to Java Control Panel --> Advanced --> Settings --> Check all the boxes for tracing, logging, and show applet exceptions. And from Java Console, select "Show Console" and OK.
http://download.oracle.com/javase/6/docs/technotes/guides/deployment/deployment-guide/console.html
Post the ani.log from CSCOpx/log directory and the java console output to see if any errors. Also ensure that firewall is disabled on the LMS server and allowing incoming traffic.  And post a screenshot of the error.
Nael Mohammad
Level 5
Level 5
Post the java console output and test it out directly on the server to see if you get the same behavior.
It's the same on the server or a client.
How do you look for java console output§?
thanks it's ok
