Per VRF Tacacs+ - not working
Dan Brook
I'm trying to configure per VRF tacacs+ on a 2901 running IOS 15.2(4)M2.
I have the following configured:
aaa new-model
aaa group server tacacs+ MYGROUP
 server-private 1.2.3.4 key cisco
 ip vrf forwarding vpn_nms
 ip tacacs source-interface Loopback100
aaa authentication login default local
aaa authentication login MYGROUP group tacacs+ local
aaa authentication enable default group tacacs+ enable
aaa authorization exec default group MYGROUP if-authenticated
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting network default start-stop group tacacs+
aaa accounting connection default start-stop group tacacs+
aaa accounting system default start-stop group tacacs+
aaa session-id common
ip cef
ip vrf forwarding
ip vrf vpn_nms
 rd 65XXX:3
 description NMS LOOPBACK
 ip address 10.10.10.10 255.255.255.255
tacacs-server host 1.2.3.4
tacacs-server directed-request
tacacs-server key cisco
line con 0
 privilege level 15
 logging synchronous
 login authentication MYGROUP
line vty 0 4
 exec-timeout 0 0
 privilege level 15
 logging synchronous
 length 0
 transport input all
I know some of this config is redundant but I have been trying different things and getting nowhere.
0 Replies 0
