PI 2.0 config archive of ASR failed
Mason Tu
Software version : Cisco Prime Infrastructure 2.0 (2.0.0.0.294)
Problem description :
When doing "Configurationi Archives", it shows "No device package found for the specified device".
But check detail in "Device Level Support", ASR should be support in PI 2.0.
Does anyone know how to solve this?
Or is there any roadmap for PI to support ASR config archive?
AFROJ AHMAD
Hi Mason,
There is an Enhancement request already filed for this issue and I can Tell you , Development team is working on the BUG. soon they will have some fix or support avaialble for config archive.
PI 2.0 - config archive failed for ASR 1002-X
CSCul19345
Thanks-
Afroz
[Do rate the useful post]
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
Hi Mason,
CSCul19345
Thanks-
Afroz
