12-09-2013 03:07 AM
Software version : Cisco Prime Infrastructure 2.0 (2.0.0.0.294)
Problem description :
When doing "Configurationi Archives", it shows "No device package found for the specified device".
But check detail in "Device Level Support", ASR should be support in PI 2.0.
Does anyone know how to solve this?
Or is there any roadmap for PI to support ASR config archive?
Solved! Go to Solution.
12-09-2013 05:39 AM
Hi Mason,
There is an Enhancement request already filed for this issue and I can Tell you , Development team is working on the BUG. soon they will have some fix or support avaialble for config archive.
PI 2.0 - config archive failed for ASR 1002-X
Thanks-
Afroz
[Do rate the useful post]
12-09-2013 05:39 AM
Hi Mason,
Thanks-
Afroz
