PI 2.1, exclude third party device from config archive
Customer runs PI 2.1. He has also third party devices in the PI inventory.
Now, every time the configuration archive job is running, this third party devices are failing. Which is the normal behavior. Is it possible to set,for example a filter, to exclude this devices from the configuration archive job?
thank you very much for your help
Hansruedi
AFROJ AHMAD
Hi Hansruedi,
we have to manually exclude them from Config collection::
Operate >Device Work Center > Configuration Archives  ,
Check the check box for "Name"  , this will select all the devices  then unselect the one you DON't want to get archived .
  click on " scheduled Archive" and scheduled it as per your need (hourly , weekly ...etc..)
Thanks-
Afroz
**Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
Hi Hansruedi,
Thanks-
Afroz
