Minimal functionality embedded access point
Antoni.Moreno
I would like to know why do my AP is so limited?
It looks like i can't do much with that... Info:
ap(config)#exit
ap#?
        configure                 Configuration method
        debug                     Debugging functions (see also 'undebug')
        no                        Disable debugging functions
        password                  New password (SPACE and TAB are not supported)
        ping                      Send echo messages
        show                      Show running system information
        terminal                  Set terminal line parameters
        undebug                   Disable debugging functions (see also 'debug')
ap#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
ap(config)#?
        do                        To run exec commands in config mode
        dot11                     IEEE 802.11 config commands
        end                       Exit from config mode
        exit                      Exit from config mode
        global-max-clients        Global Max Clients
        interface                 Select an interface to configure
ap(config)#int ?
        BVI                       Bridge-Group Virtual Interface
        Dot11Radio                IEEE 802.11 WLAN Interface
ap(config)#int dot11 ?
        <0-0>                     Dot11Radio interface number
ap(config)#int bvi ?
        <1-1>                     BVI interface number
ap(config)#dot11 ?
        guest-ssid                Configure radio Guest service set parameters
        ssid                      Configure radio Main service set parameters
ap(config)#
Router
#sh ver
Cisco IOS Software, C860 Software (C860VAEW-ADVSECURITYK9-M), Version 15.3(3)M2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Thu 30-Jan-14 02:21 by prod_rel_team
ROM: System Bootstrap, Version 15.3(3r)M, RELEASE SOFTWARE (fc1)
Router uptime is 1 day, 1 hour, 10 minutes
System image file is "flash:c860vaew-advsecurityk9-mz.SPA.153-3.M2.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco C866VAE-W-E-K9 (revision 1.0) with 385024K/32768K bytes of memory.
Processor board ID GMK1730008Z
1 DSL controller
1 Ethernet interface
3 FastEthernet interfaces
4 Gigabit Ethernet interfaces
1 ATM interface
1 terminal line
1 Virtual Private Network (VPN) Module
255K bytes of non-volatile configuration memory.
131072K bytes system flash allocated
While checking more details on this series of Router with embedded AP, it seems it is unlike the other models of 8xx series.
The C86xVAE-W router models (C866VAE-W-E-K9, C867VAE-W-E-K9, C867VAE-W-A-K9, C867VAE-POE-W-A-K9) contain an embedded AP called the AP860VAE. Unlike the AP801/AP802 in other 8xx routers, this AP does not run IOS, but is a Broadcom AP running Linux.  It can only run in autonomous mode (does not support CAPWAP).
The AP comes out of the box configured with 4 SSIDs, Cisco860, Cisco860_Guest1, Cisco860_Guest2, Cisco860_Guest3, with the Cisco860 SSID enabled and open.  A client can associate to the AP and will, by default, get an address from 10.10.10.0/29.  The AP's address is, by default, 10.10.10.2.
You can telnet to the AP CLI.  You can do this the same as you would with an AP801/AP802, i.e. reverse telnet out the router's line 2, i.e. telnet to the router's IP address, TCP port 2002.  It does not appear that the AP860VAE supports telnet or ssh itself.  It does have an HTTP GUI interface.
The default username/password on the AP860VAE is admin/admin.  You will be forced to change the password when you first log in.
Unfortunately, there is no VLAN support for the AP860VAE.  I.e. the Wlan-GigabitEthernet0 interface on the router must be an access port, and whatever VLAN that is in, that's what the AP860VAE - and all of its SSIDs - are in. CSCuo04717 Bug-Preview for CSCuo04717 has been filed as a doc bug, to reflect this clearly in documentation.
Ideally it is recommended to have most of the configuration using GUI which is much easier compared in CLI.
Configuring steps from GUI are present here, please check :
Configuring WLAN using web-based interface
 -Thanks
Vinod
**Encourage Contributors. RATE Them.*
-Thanks Vinod **Rating Encourages contributors, and its really free. **
6 Replies 6
Vinod Arya
I am sure the 800 router series embedded AP's have almost all the necessary configuration required for an AP to work properly.
Following is the guide for Basic Wireless Configuration for Cisco 800 Series ISR. You have to be specific, on if you think the AP is missing some features in it:
http://www.cisco.com/c/en/us/td/docs/routers/access/800/software/configuration/guide/SCG800Guide/SCG800_Guide_BookMap_chapter_01001.html#con_1059792
Please check and verify if you think there is something missing as compared to the Cisco Unified Wireless infrastructure AP's.
-Thanks
Vinod
**Encourage Contributors. RATE Them.**
Hi, Vinod
Thanks for you reply.
It seems that all docs are referring more to 880 and 890 and since i have a 860vae-w-e-k9 the cli commands are mostly not fitting i'll explain:
First i do not have the interface Wlan-ap0, it's just does not exist.
service-module wlan-ap 0
Interface Wlan-ap0 not producing any result my assumption is that the 860vaew model doesn't even have this interface in the build.
May be that this is my Wlan-gigabitethernet0 who knows??
In addition when i try to configure a Vlan to SSID it's not possible.
Dot11radio is only from 0 to 0.
Please look at my configuration options there not so many.
Can be that i have the unified image loaded?? cause i use autonomous i don't have a WLC.
Going crazy have ben reading almost every 860 docs but it seems that it's all referring to 880 and 890 not 860.
 -Thanks
Vinod
Vinod, Thanks for the quick reply.
I did all of the above written before but didn't get confirmation for the true capabilities of the router until now.
So it seems that my biggest fear was to find out that the router is low end product.
I wouldn't call it junk but in terms of access point i'm afraid that's true.
I got all running but now it's all clear.
What i was trying to do is to isolate the guest SSID from the main SSID (ssid isolation doesn't work).
In addition web access doesn't work for me.
interface BVI 1
ip address 10.10.10.2  255.255.255.0
no shutdown
Router#sh int vlan 1
Vlan1 is up, line protocol is up
  Hardware is EtherSVI, address is xxxxxxxxxxx)
  Description: $FW_INSIDE$
  Internet address is 172.16.0.2/24
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive not supported
  Last input 00:00:00, output 00:00:08, output hang never
  Input queue: 1/75/0/0 (size/max/drops/flushes); Total output drops: 2
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 2000 bits/sec, 2 packets/sec
  5 minute output rate 1000 bits/sec, 2 packets/sec
     1610777 packets input, 246605928 bytes, 0 no buffer
     Received 7479 broadcasts (7642 IP multicasts)
     2203367 packets output, 2602583339 bytes, 0 underruns
     0 output errors, 1 interface resets
     7612 unknown protocol drops
Router#ping 10.10.10.2
Sending 5, 100-byte ICMP Echos to 10.10.10.2, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Router#trace ip 10.10.10.2
Tracing the route to 10.10.10.2
VRF info: (vrf in name/id, vrf out name/id)
  1 DSL modem (192.168.0.2) 4 msec 4 msec 0 msec
  2  *  *  *
  3  *  *  *
  4  *  *  *
  5  *  *  *
  6  *  *  *
  7  *  *  *
  8  *  *  *
access-list 1 permit 10.10.10.0 0.0.0.255
interface Wlan-GigabitEthernet0
 description Internal switch interface connecting to the embedded AP
 switchport trunk allowed vlan 1-3,1002-1005
 switchport mode trunk
 no ip address
What is wrong here?
8xx series was intended as a router with AP capabilities. This one is unfortunately have very basic wireless functions.
The default ip address to access the GUI ( via the BVI interface ip address) is 10.10.10.2. Default username/password is admin/admin. Upon initial login, user will be prompted to change the default username/password.
As mentioned, there is no VLAN support for the AP860VAE.  I.e. the Wlan-GigabitEthernet0 interface on the router must be an access port, and whatever VLAN that is in.
Though it mostly seems to be on the routing configuration for reachability, you can try to configure another IP on the BVI interface to see it works properly.
You can later check with show interfaces BVI 1 command for more statistics on this interface, if any drops etc.
 -Thanks
Vinod
Vinod, can you confirm whether it's possible to disable the web GUI for the AP?
I would prefer for this to be disabled, and it doesn't look like the use of the no ip http server command is valid here.
